Whys that? What kind of soil do you have? It looks real light brown.Just to follow up - I went in-ground. 1000 gallon. Should be good for a while.
I like the new tupperware top they put on it. What I don't like is the plumbing job they did...
View attachment 135590 View attachment 135591
Whys that? What kind of solid do you have? It looks real light brown.
Thank goodness oil companies don't work like that. I can buy oil from anyone and use as much or as little as I want and noone complains.I looked at it but be careful. A lot of propane companies I talked to said they would only fill their tanks, which made shopping around for the best price impractical. They will put in the tank for free but if you don't use enough they charge.
what's wrong with the plumbing? it looks like a typical lazy "gasman" job. it would be better if the black pipe nipple was shorter, but otherwise nothing unusual about it.
But who owns the oil tanks? The homeowner owns them I'd think. Oil tanks are prolly much less costly than LP tanks since oil isn't a pressurized gas that will expand to 270 times it's volume changing from a liquid to a gas.Thank goodness oil companies don't work like that. I can buy oil from anyone and use as much or as little as I want and noone complains.
Put the cover on... Out of sight out of mind.Exactly. If it was shorter then the tube wouldn't have had to take such a hard turn out of the top. It doesn't leak, but it's not pretty...
That will be nice and they can make the equipment with a small or no footprint don't they!Up until now, I had oil heat my whole life. I won't miss all the space the tanks took up in the basement or the lingering smell after servicing, or the servicing for that matter. Here's all my mechanicals in the new house (blue well tank on the right got cut off in the pic)View attachment 135691 .
I wander how they inspect a underground tank?
There are loads of underground propane tanks here.
I covered my well head with a fake rock. Can you do that with the tupperware?
Here is an installation photo; there were some initial issues:
