If I don't want that hot of a fire, for example in the warmer spring and warmer fall rather than in the dead of winter, does it extend the lifespan of the catalyst to just be bypassed? Or is it better to always engage the catalyst and just open more windows if I want the house cooler?
Another situation that happened once, is I got non-ideal firewood, definitely not rotten but a little punked out from fungus or whatever, just not my preferred wood quality. So I want to burn this junkier wood in the warm season and bypass the catalyst so I don't risk having a lower quality wood gum up the catalyst, is that sound thinking?
What is the best way for a good hot fire, when the catalyst is engaged, that you intentionally wish to burn out completely to a cold stove? Do you leave the catalyst engaged, or when do you bypass it; does a certain method work best insofar as prolonging catalyst life span?
Thank you
Thank you
