Chas0218
After a very warm weekend in the house I've been trying to figure out how to run it at lower temps so we don't waste wood or sweat to death.
Let me know when you figure this out. haha
I've tried smaller fires but my chimney doesn't seem to get warm enough. The single wall surface temp just before it goes out the house to the tee is around 170* with small fires and around 280* with large fires. I don't think that is hot enough with smaller fires and I really don't want stage 3 creosote build up.Smaller fires is the trick. We had a 6 hr power outage yesterday which started before the heatpump came off the nightime setback temp. By 11am the house was at 66F and my wife was complaining about being cold. I reluctantly started a fire considering it was 54F outside. The fire was made with 2 smallish 4" splits and two 7-8" splits. The house got up to 71º and stayed there. Power came on a few hours after I had started the fire so I just let it burn out.
Good to know thanks.We had good secondary combustion which surprised me considering how warm it was outside. Probe flue temp settled in at around 400F. With a surface temp of 170, the flue gases should be above 250F. If the wood is dry it should be ok.
![[Hearth.com] Progress Hybrid Install and Experience [Hearth.com] Progress Hybrid Install and Experience](https://www.hearth.com/talk/data/attachments/250/250332-bf4c79679c1cba4c699408fd83ad7e4f.jpg?hash=kQ2lPREKdq)
Doug fir seasons quickly once split and stacked. I get our doug fir in early spring and load the shed with it. It has consistently come in at around 18% moisture content by Nov. 1.
Have you considered getting a probe flue thermometer to track flue temps?
A probe thermometer is all that will provide an accurate reading with double-wall stove pipe.Yeah he brought the trees down early spring and by late spring it already had that nice dry tone to it. Tested in the high teens last week.
Ive thought about a flue thermometer but i dont like how they are just a metal probe which conducts heat to a coil thermometer. Do those still work well with double wall pipe?
I installed a heat shield behind my double wall pipe to reduce wall temps. Even though my stove meets clearance requirements I could barely hold my hand on the wall during a hot burn
I don't have experience with double-wall, but I'd think that with clearances met, the wall shouldn't be getting that hot unless you are firing your stove and flue pretty hard, as in a strong hybrid burn with lots of secondary action. I'd get a probe in there to see what flue temps are. I'm not sure what kind of temps the double-wall connector is rated for..? (Or single-wall for that matter.)Have you considered getting a probe flue thermometer to track flue temps?
You bring up something I've been wondering about, as I try to get the hang of finding the "Goldilocks zone" with my SIL's new secondary-burn stove. When you say the more dense wood "burns cooler," I guess it's because it gasses in a slower, more controlled manner than the lower-BTU stuff you burned? With the low-BTU wood, it's more likely I'll get too much of the load gassing early on, then stove temp goes higher than I'd like.tight grained douglas fir trees....This wood burns a little cooler for much longer than random mix I burned last year.
Huh, that sounds like my experience with the new secondary stove..gotta be careful not to get too much wood gassing. I was under the impression that one could go to a cat-only burn with the PH at any time, just by cutting the air back. Maybe that was more the case with the steel hybrids, not sure.The stoves temp is pretty much only controlled by the amount of wood you have in it but even doing a hot reload half full it will put out some pretty good secondary action for a couple hours....Once the stove is up to temp you pretty much have to have the air control fully closed or it will really take off.
I know that with my Woodstocks, the stove top meter was the slowest to react, with the soapstone and all. Those have been straight cats though, not hybrids..your PH top may react faster once the secondary kicks in. I also have a surface meter lying on the horizontal tee snout, and in my case it reacts faster to changes in the fire box. I know that if I hold it at 450-500 for ten or fifteen minutes, I can close the bypass and get a good light-off. You too may find flue temp more useful in judging what's going on in the box. Maybe the best tool is just looking at the load to see how much wood is catching at a given time and cutting back the air accordingly. But it takes a while to get good at judging a fire by eye, and anticipating what it's going to do in the next several minutes. I'm having to hone those skills now, at my SIL's. At home, if I get too much wood burning in the Keystone, no big deal, I just cut the air to tone down the burn.I did just order a pipe thermometer to see if that gives me better info for startup and closing the bypass.
I agree with you on the nicer higher BTU wood. Additionally it nests together tighter because its so straight which I think helps regulate the burn.
That is similar to what we see with the T6. Lately with cold nights and mild daytime temps I have been starting a full load fire around 7am, then a modest 5-6 split reload around 6pm. I toss a few splits on at around 11:30pm to carry the fire through the night. So far this heating season I have cleaned out ash twice burning almost all doug fir, about 2 cords worth so far. Lately I have been slipping in some hardwood for the 11:30pm burn and that is building up ash quicker. I will have to clean again by the end of the month I think.Another quick mid season update. There was a thread at one point where someone was complaining at how often their cat clogged, i think they were having to clean weekly. With my previous batch of lower quality "Northwest mix" wood I'd need to clean about every face cord, maybe each time I had to empty the ash pan. But having put a cord of douglas fir though the stove, the cat has hardly any ash buildup. So if you are getting clogging problems it could be an issue with your wood.
12 hour burns with doug fir are still not guaranteed but I don't try for that long most of the time. If I get a few big logs on bottom when I light a fire from the middle, that seems to be the best for long burns. I do easily get 12 hours of heat from the stove though. In my relatively mild climate if I wanted to do 24 hour burning it would probably require 3 or 4 smaller reloads a day in order to not heat up the house too much.
That is exactly the same way that I clean mine! Works great!Did my annual chimney cleaning this week:
My apparatus to capture soot, a helper holding a shop vac near the hole would make it nearly soot free.
Probably got 1.5 qts of soot. The lighter browner part was from the stove pipe, the darker black stuff from the chimney.
Have you given it a vinegar bath? It does wonders to rejuvenate.Its been a few years now and I think my cat is not really activating anymore. This will be my 6th season and last year it seemed to be not giving me cat burns much anymore either. To keep the stove up to temp I have to get it hot enough to have secondaries fully going and all of the logs good and coaled over. If I shut it down too early, instead of going into alien heat mode it will just slowly cool off. This has also been verified by looking at the smoke output.
I've ordered a new cat from Woodstock, $220 delivered to Seattle, and will report back when it comes. Currently backordered with a 6 to 8 week delivery time but the guy on the phone says he hopes it will be sooner.
