Not wood-fired, but I figure you guys might know.
A friend of mine drained his boiler because of the power outage.
He refilled it yesterday, but can't get it to heat.
Burner fired up and shut off at water temp of 180F.
Very little warmth coming from outlet.
It has an Extrol expansion tank with air scoop and that air valve on top.
It appears to filled, apparently too much since we fooled around with it without reading and it's at 20 psi now.
I understand that for his 2 story house it should be at 12 psi to match the expansion tank and fill valve (we put it on fast fill).
He swears there're no bleed valves.
I figure it's big air bubbles, but how to purge?
A friend at work suggested isolating each zone (there are 4 including the water heater), and cracking open the drain valve at the circulater to purge the air.
Any other ideas?
He'll probably just wound up hiring a plumber to come out, but they may be scarce with the power failure.
Thanks.
Any other ideas?
Thanks.
