i will do just that. Thanks for the tipI suggest you purchase your next combustor from a dealer if you want OEM precious metals coatings.
You can try Midwest Hearth. Their combustors are supplied by Applied Ceramics.
Masking is a process where build up keeps smoke from "reaching" the precious metals coating.here's a thought. We inspect the combustor monthly (removing the combustor shield, getting down on our knees with a flashlight). we find after 2 or 3 months of burning, half of the combustor's surface is covered with ash with many cells plugged. so we switch out the current combustor with another one. We clean up the original one by lightly dusting the surface with a soft brush. could our cleaning be shortening the life of the combusters?
Yes, many times. But do it outdoors...it stinks! And have gasket on hand.i've read about the water/vinegar process but didn't really believe it would work without damaging the combustor. has anyone used this process with success?
I'm not sure if they use a different construction for the BK cats, or if they've changed in recent years, but those Condar Steelcats used to literally fall apart in a year in my old Jotuls. I know the Jotul cat stoves left a lot to be desired, but ceramic cats never imploded the way those Condar Steelcats did, in those stoves.We get our combustors from Condar
paging @Highbeam. He has done this more than once, I think.
Here ya go. It's in the main forum because it's not BK specific.I posted a whole article/thread about a vinegar boil of a worn out steel cat. It’s been years though and I can’t remember if it was swept into one of the general BK threads.
Regardless, it did not harm the combustor at all. It revived the catalytic function to respectable levels for just a few months.
I concluded that it just wasn’t worth the cost of time, gasket, and vinegar. These cats aren’t very expensive when you get at least two years out of them as I have. Fresh cats work better.
You have an air leak around a gasket. Either the loading door gasket or the glass gasket. Ceramic cats don't fail after 6 months.
Check gaskets. How long do you leave loading door open when starting and also when refueling. Do you load snow or ice laden fuel? The thermal shock you are experiencing is not common. Let's rule these out first.
BKVP
Fixed your statement, at least with regard to the Ashford 30.Ceramic cats don't fail after 6monthsyears.
Funny but OP says they fail after 6 months...that deserves attention to find solution.Fixed your statement, at least with regard to the Ashford 30.![]()
When I get around to pulling mine for cleaning in September, I'll take a photo of a 6 year old ceramic cat. Zero cracks, zero spalling. Other than a little discoloration and staining, it looks almost like the day it was mailed to me.
Francisco was very helpful. Our dome guard has been ordered. thank you muchlyCall my office on Monday and speak with Francisco. He can make a recommendation.
509-522-2730
I'm flying next week, so he'll help you.
Chris
