I'm a newbie and took on the project of replacing the tiles on my fireplace hearth. As things do, it's gotten a bit complicated.
The tiles were brick inlay that were embedded in the concrete or mud base and were not coming off so I ended up removing everything expecting to hit a flat wood or concrete base. Instead I reached this concrete hump
and this is what it looks like underneath from a closet in my basement.
![[Hearth.com] Pouring concrete for new hearth [Hearth.com] Pouring concrete for new hearth](https://www.hearth.com/talk/data/attachments/197/197990-74712dcd7365efe9ed353863f208afef.jpg?hash=3T5zSoA6x4)
My plan was to fill the heath in with concrete and then tile on top but having never poured concrete before and knowing that if I end up with a slab that it not level or the exact height I need, I'll need to break the whole thing out again, I have the following concerns:
- should I be concerned about the weight of the concrete? Can I assume that since the previous concrete and brick held for the last 50 years that it can support the weight of the new concrete?
- the wood frame in the hearth looks solid but should I be concerned about possible pressure from the concrete buckling the wood?
- because I want the new tile to be flush with the wood frame on the floor, the height of the slab will need to sit below the surface to account for height of tile and thin set. How do I screed below the surface? I thought about cutting notches in the ends of a 2x4 so the middle portion sits below the surface. Is that the right approach?
Watching some slab pouring videos online, it essentially seems to be pour, distribute the concrete, screed, smooth out and float. Am I missing anything here? Anything else I should in keep in mind so I don't screw this up?
Lastly, my other option is hire a pro to come in and lay the slab. Given my concerns and relative inexperience here, should I consider that or is this not that complicated a job?
![[Hearth.com] Pouring concrete for new hearth [Hearth.com] Pouring concrete for new hearth](https://www.hearth.com/talk/data/attachments/197/197991-ba352681176de7d6ea78d461d7b44eaf.jpg?hash=OG-TuvJmKB)
