I have been fooling with this problem for coming up on seven years now.
https://www.hearth.com/talk/threads/regulated-burners-cold-start-tips.140279/
I have no reason to think my draft is unusually weak or strong. With house guests that needed to remain fully clothed I was able to get a 36 hour burn out of my A30.0 with outdoor ambients in the +20 to +30 dF range. It remains my personal long burn record with an active cat, but the house was not warm enough (given the fully clothed guests staying over) for my wife to be in the wardrobe I desire. At -30dF and colder I can burn down a box full of spruce in 4 hours. Everyone here will have better/ stronger draft at -30 dF than they do at +30dF. I conclude my draft is average/ typical and have intentionally not commented on any of the damper conversations I can recall.
The EPA reg requiring regulated burners to get from cold iron to clean plume in 20 minutes should not be on the books because it is not safely attainable by average burners using average fuel in average installs. I don't know any above average burners with above average fuel that can do it, not one. Period. See you in court.
Please keep in mind, first lit kindling to engaged combustor is not the same interval as first visible plume of smoke at opacity of 50% to clean plume. There have been several folks in the last few years mucking about with engaging their combustors early. The general idea is "I know my stove, I know my probe runs about ten minutes behind reality, I know my fuel, therefore I have been engaging my combustor 10 minutes before it would get to the active zone and I haven't broken anything yet." But none of them, zero people, have been able to photographically document that process got them to clean plume any faster.
I will quietly admit I have fooled around with engaging my combustor early back in Feb 2015 and I found no consistent measurable improvement in total time to clean plume.
If you can think of something I haven't tried I am all ears, but I would very much prefer to get the bad rule off the books or ammended.
Depends upon the substrate. Ceramic combustors, from a cold start with #5lbs of kindling, about 20-25 minutes. With the metal monolith combustors, same conditions, about 15 minutes.I don't think it can be done safely with a typical average install. One thing to keep in mind is registered users here are among the most conscientious burners in North America. BKVP says so several times annually and mentioned "us" as a group in particularly glowing terms just in the last week or two.
From previous F2F conversations with Chris over the years, the typical burner, who isn't registered here, is running fuel at 20-22% MC, and all the stoves from all the manufacturers are designed around that finding. When we start loading fuel at 18-16-14 % we are pushing the design envelope already.
So let us just ask Chris and get it over with. @BKVP, loading fuel at 15-20% MC on a typical/ average chimney how fast can we reasonably expect to consistently get to active combustor without overheating our chimney pipes?
You're welcome.So at this point, I guess I just got the pipe a little too hot, and no actual fire occurred, which is comforting. I really appreciate the help and guidance from the group.
This exactly. On BKs at least, anytime the combustor is pulled a new gasket is required.Yes, have gasket available before you pull out the cat. It will always fall apart.
You are understandably focused on the plume.
Here's my blanket statement: If you think something's not right in your flue, you should look.
Takes 5 minutes, and a wifi endoscope long enough to scope out the whole run costs $30 on amazon.
If you have to call The Guy to come do it for you, that's a substantial barrier to you actually getting it done, and an even higher barrier to you getting it done frequently. (And yes, you should be looking frequently as you get to know a new stove.)
I got nothing man. Up here at 64 degrees north latitude a weak cat is a replaced cat. If this works for you down south, carry on. I will check the green room tomorrow to see if you want to talk about snow tires. I am not here to tell folks what they should do. I am here to explain what works for me up here.Unless you make stainless steel shims to go around the perimeter of the cat.
Frequent cleaning has been awesome for my elderly cat.
Do squirrels really burn that clean?There are a number of folks, even here among the consciegenti, who equate engaged combustor with clean plume. It simply isn't so.
If engaging the combustor results in a clean plume instantly, there are four possible explanations.
4. Squirrel!
Got a link? I'm game, but don't see anything that would make sense at that price point. Go in from the bottom or the top? Care to share some examples or point to a good thread?
With me being new to stand alone stoves in general, it was worth it to me to pay someone for the second opinion and confidence that brings. In the future, seeing that he went in from the bottom for the cleaning (that wasn't possible on my last insert), it means that I can do a lot of the maintenance and inspection myself, and be confident about it.
For what it's worth, with the Condar temp probe in, it seems pretty easy with my setup to get things above 1,000* if left wide open for 20+ minutes. Most times on a hot reload, I'm starting to turn it down by 12-15 minutes to keep it around 800-900 reading, taking into account the delay on the probe. I may have to purchase a thermocouple for my fluke to do some more testing and get quicker results.
Don
Squirrels are everywhere! I can be in the middle of a conversation and they just walk past my door at home, office window, powerlines while driving....Do squirrels really burn that clean?
Maybe we've been going about it wrong burning wood all these years...
