I've started discussions with a propane tank manufacturer along two lines:
1) Making a tank designed for hydronic system heat storage. Basically a lighter duty propane tank sized to fit through a normal doorway and stand on end in a normal basement. Probably be around 200 gallons - maybe a bit more. Would be ASME tanks designed for 30 psi operating pressure, and would have fittings in the ends and internal baffles to reduce mixing and maintain stratification.
2) Modifying refurbished propane tanks with more useful fittings to facilitate use in hydronic systems.
For dealers and system integrators / installers: Any sense of how much actual interest there might be in such products? Don't need firm numbers, but I'd like at least a rough sense. These would probably be sold through existing propane tank distribution networks, but if any dealers are interested I'll be glad to connect you with the manufacturer,
For everyone: Any thoughts / suggestions / comments? Anyone willing to be a test bed?
I won't be involved in any way other than being a catalyst. I'd like to see something along these lines, and it seems like the time is right. Based on the price of propane tanks, these ought to be a lot less expensive than other commercial pressurized storage options.
