Hello
The cord and plug was hot because it was on a 15 amp circuit with other outlets and it was oxidizing & corroding!
According to this article.
The pump outlet should be on a 20 amp separate circuit with an NEMA L520-R Turnlok Receptacle and a NEMA L520-P Turnlok Plug![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
See details below and except in pic below.
So I had an Intermatic Pool filter timer to add in so now is the time to do it?
Any other comments or suggestions?
It works!
So should we be safe from electrical shock or Fire at this outlet now?![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
Pic 1 - recommend outlet
The pump motor is 13.8 amps so 15 Amp outlet is cutting it too close, so that is why the old plug is overheating.
Pic 2 - original 3 prong plug![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
Pic 3 - Hayward Filter pump motor specs
Pic 4 - Original 15 amp Bubble outdoor outlet on a 15 Amp GFCI breaker wired using white 14-2. Just not good enough!
Pic 5-7 New 20 Amp Turnlok plug & receptacle wired with yellow 12-2
Pic 8-10 GFCI 20 amp Circuit Breaker & Intermatic Timer hookup
It works!
