maple1
That seems odd - all thermostatic valves I have seen are right at the boiler. Even mounted on the back of it, if it's an OWB. With the underground heat loss, I don't think it's doing it's job correctly & the boiler is getting return water that is cooler than it is supposed to be.
What you said about the manifold should work unless I'm still missing something - each boiler circ would simply turn on when it needs & calls for heat, shouldn't be any 'balancing' needed. You would need a supply manifold, and return manifold. Also have no idea what your existing controls are either - so that might need some work too. And still don't know about pumping at each indoor boiler. Might need some flow checks but might already have them?
