Plumbing free standing wood stove into a 6”x8” clay chimney flue
Update:
Broke all the clay, what a mess that was. Sent the liner down the chimney this morning and got snagged about 18’ down. I twisted, wiggled, spun, anything I could do to get past that point, but couldn’t. This point in the chimney doesn’t look quite plumb and there’s a little mortar from a joint. Ordered a pulling cone. Going to give it another go when the cone arrives.
Reactions: bigealta
Update:
I had one offset in a 12x12 with some mortar sticking out. We had two people up top and one in the basement and just barely made. I used abs shoving that liner down I didn’t know I had.
Remember you can pull flexible liner apart. If you can see the mortar maybe you could get creative and remove some of it.
Reactions: cmyers
It might be good to lower a camera down there. Maybe use a cellphone securely strapped to a rope?
Reactions: cmyers and EbS-P
I’m thinking about sending the tile breaker back down and chipping it a little bit. I can see it from the top of the chimney.
Reactions: begreen
U might be able to knock the mortar squeeze out off with 2 10ft 3/4 or 1" pvc pipes screwed or glued together. That's what i use as my chimney brush extensions. I tape the brush connected to 1 length of chimney brush rod to the pvc. Then when i get 10' down i can put the 2nd 10 ft. male end in the female end and i bolt them together thru a hole i drilled in each one. Works great.
That sounds like a good plan.
