Ashful
Dead wrong. Our ancestors heated their houses solely with fireplaces until the late 18th century, and many of us still do. In fact, a fireplace has the capacity to throw more radiant heat than almost any stove you can buy today, at the cost of low efficiency and shorter burn times.Don't expect to get much radiant heat from it, as fireplaces are usually just for looks.
Better.If you expect heat: a fireplace simply gives off a bit of radiant heat but the majority goes up the chimney. An insert will allow you to effectively heat an area with wood within the open area of a fireplace.
Correct!A fireplace is decorative and can be fun, but it really isn't a very effective way to heat the house. You lose almost as much heat up the chimney as you get from burning the wood.
An insert will make the fireplace into an effective part of your home heating system. You'll get much longer burns from the same amount of wood, and you'll lose a lot less heat up the flue (chimney). Of course the insert will be much more expensive than the minimal stuff necessary that a couple of previous posters listed.
A fireplace is actually an EXCELLENT way to heat the room in which it is located, but unfortunately it does so at the expense of the rest of the house. I grew up in a house with four fireplaces, so I know of what I speak. Fireplaces can throw an enormous amount of radiant heat, but the make-up air requirements causes rooms distant from the fireplace to go cold, drawing air from outside thru windows, receptacles, and other points of draft, to supply the fireplace requirement.
I enjoyed very much heating with fireplaces, but the wood usage was very substantial (eg. 20 cords per year), and they must be tended frequently. You cannot get a 12 hour burn time from a fireplace, but I do just that daily with my woodstoves.
Unless you need to offset the cost of your central heating, I'd just plan to use those open fireplaces a year or two for ambience during evenings on the couch, to see how you enjoy the whole wood processing and woodburning experience. If you find you're into it, then maybe it's time to invest in a stove or insert, for the purpose of serious heating. I am able to cut my oil usage in half (or better) by burning wood, but it is a lot of work, likely beyond the interest of most folks.
