hello again to the wonderful "hive mind' of the boiler room
as those of you who are following my [mis]adventures know, I am deploying an Econoburn with a really big unpressurized heat storage tank that will have 8" of surplus polyiso underneath, a foot on each side, and a foot or more on top (the "BIG tank").
All that, via primary/ secondary pumping will be hooked to a ridiciulously large water to air HX coil
that "BIG coil" will sit on top of my existing ThermoPride oil warm air furnace, which has a wonderful high volume, low velocity belt-drive blower in it, and the same blower (in the ThermoPride) will push the air through the BIG coil into my preexisting ducts
the thermostat will call for heat and turn on the secondary circulator to the BIG coil, plus the appropriate primary circulator and circs from the boiler or tank, whichever is hotter.
then, when the hot water gets moving to where the outlet of the BIG coil is hot, I'll want to kick the blower on.
Originally, I was thinking of a thermal "snap switch" to do that
now, am thinking of a PLC and thermocouple put into one of the spare 1/2 npt female joints on the water return side of the BIG coil that's now occupied by a plug
that way I can vary the parameters, and maybe someday even have a variable output from the PLC control a VFD for a 3 phase motor or a stepped multi-speed motor, so that the motor follows the heat, to maximize how much heat I can pull from the tank, through the BIG coil, even as the tank drops to 120 or even 100
[slower air flow through a cooler coil might still pull useful BTUs from a cooling tank, with less overall electricity used]
anyone have any suggestions on vendors of good PLCs and fittings for the associated thermocouples to go into a 1/2 inch female NPT?
Or am I just over-thinking this?
thanks
Trevor
thanks
Trevor
