ok, I'm getting things wrapped up in my boiler shed now. I need to insulate the pipes in there to minimize heat loss. Slip on insulation is out of the question due to the insane cost. Fiberglass wrap is out due to the fact it doesn't work well if it should get wet somehow.
So I'm looking at two-part spray foam (basically, DIY corbond, just like we're using on underground lines alot now) with an r-value of about 6.5 per inch or this bubble-wrap insulation: http://cgi.ebay.com/Plumbing-Pipe-W...ryZ63894QQrdZ1QQssPageNameZWD1VQQcmdZViewItem
They're claiming an r-value of 11 for that stuff... I find that very hard to believe... But, if that stuff works well, It'd be my best value as the spray foam kits at the local hardware run just over $1 per board foot....
For 8$, that wrap insulation will do ~35 feet of 2" black iron pipe.... which would take about 19 board feet of spray foam at $19-20. (Although you end up buying the whole $200+ dollar kit whether you use it or not....)
I guess it comes down to this: Does the bubble wrap work like it says? I can buy the spray foam kit and use the stuff left over from the pipe insulating to seal up my boiler shed.... It won't be wasted. I'm just looking for what will be best for pipe insulating.. I have all the pipes in the shed, in my basement, in my shop, and in the milkhouse to insulate...
