This simple small stove appears in mint condition, however it will not draw, and fire is immediately choked off as soon as you close the door. It has only one control, a knob connected to a thermocouple thermostat which controls a round flap valve at the bottom right of the unit.
Fortunately, i tested this unit outside with the valve wide open and 4’ of flue pipe attached. The chamber for the air intake feels clear (i stuck a wire cable up and it went freely to the top and no debris was dislodged. with the flu pipe removed, i can manipulate a metal plate that is loose, it can flip to the back which seems to open the path from the firebox or to the front which closes it. Neither position affects performance. (with flu pipe installed, there is no way to manipuale this plate other than tipping this 400 lb stove ) when i picked up this stove, i heard the plate banging around when it was tilted back on a hand truck.
Anyone seen one of these? It looks like the top will come off with just 4 bolts removed, exposing all the innards…
There is virtually no information that i can find on the web for this old stove.
