Connecticut Yankee
Burning Hunk
Having a T inside the house doesn't have to be a disaster. Our pellet stove replaced a wood stove, so we were forced to run the vent up to the existing 8" thimble and run a flue up inside the chimney. When I remove the caps from the T's (one at the base of the stove, the other up at the thimble, there is never enough accumulated ash to pose a problem. Though I grant you, it might be a different story if I didn't listen to you guys about frequent thorough cleanings!Guess the manufacturer of the unit wants you to destroy the interior of your house then. Putting a cleanout Tee inside is a no no unless it cannot be installed on the outside for some reason. Believe me, you leave it inside and the first time you pull the cap, you'll understand perfectly why it needs to be on the outside.
