I have had my pelpro 130 pellet stove for 2 days and started acting up 7 hours after installation turn he dial to 5 it drops pellets ignites and goes out immediately
Hi Tami and welcome. We are going to need a little more info in order to help you.I have had my pelpro 130 pellet stove for 2 days and started acting up 7 hours after installation turn he dial to 5 it drops pellets ignites and goes out immediately
Followed the troubleshootingHi Tami and welcome. We are going to need a little more info in order to help you.
1. Did you read the manual and following the trouble shooting section on fire lights and then goes out? See below.
2. Describe the venting system you are using and what pellets are you using.
3. If you have been burning the stove for seven hours I assume you have just recently added another bag of pellets. If so make sure the hopper is closed correctly so that the hopper switch is working.
4. Did you install the stove or was it done by a dealer?
Burn pot is correct double checked that to make sure. Yes one the light it is red and blinking one time followed the troubleshooting guide and cleaned everything and started over starting it up and does the same thing . Have adjusted the trim as well still no luck.If you cleaned there burn pot by removing it di you get it sitting back in the stove correctly ? Also are there any blinking codes at the control panel when the stove shuts down ?
Looking closely at the burn pot are the holes in it all clear of carbon build up ?Burn pot is correct double checked that to make sure. Yes one the light it is red and blinking one time followed the troubleshooting guide and cleaned everything and started over starting it up and does the same thing . Have adjusted the trim as well still no luck.
Took the tool and cleaned out all the hole really nothing but a little dusting in them so that's good toLooking closely at the burn pot are the holes in it all clear of carbon build up ?
that all cleaned out took it all apart and vacuumed out that was it i think.( no we didn't find a finger)We started the stove back up what really seems odd is the convection fan comes on but doesn't run on high like it would if you were shutting it down its more of a low and slow so the fire seems very large now we have adjusted the trim to the negative side and it sure doesn't seem to help is this normal?Hate to tell you but maybe something stuck in the auger flights? Never know what may have been dropped in the hopper and has finally bound up enough to limit the pellet feed. Sometimes there is objects in the feed while bagging, lost fingers(well they never did find his finger), string, wood chunks and plastic bits to name a few things found and then there is the stuff young ones have lost while playing.
So I would pull and suck out everything and see if anything is choking the auger flights.
Ok so that didn't last long I started the pellet stove 3 hours ago and it ran fine till right now . I was running it on low again pellets quit feeding and the fire went out the light on the stove by running it on low is ember color and was still ember when the fire went out never went into shut down mode which it should not because I am running it in a continuous setting so why would the fire go out?Took the tool and cleaned out all the hole really nothing but a little dusting in them so that's good to
now also I try to start it back up it drops pellets they light and they immediately go back out but the controls thinks its still running and its not.Ok so that didn't last long I started the pellet stove 3 hours ago and it ran fine till right now . I was running it on low again pellets quit feeding and the fire went out the light on the stove by running it on low is ember color and was still ember when the fire went out never went into shut down mode which it should not because I am running it in a continuous setting so why would the fire go out?
Did it burn up all of the pellets or did the pellets stop burning?Ok so that didn't last long I started the pellet stove 3 hours ago and it ran fine till right now . I was running it on low again pellets quit feeding and the fire went out the light on the stove by running it on low is ember color and was still ember when the fire went out never went into shut down mode which it should not because I am running it in a continuous setting so why would the fire go out?
The first is not enough fuel, and the second is not enough air. When the fire died out all I had was embers and yes they do finish burning up in time as an ember. Yes I do agree that there was not enough fuel but that's only because the pellets stop dropping when it is running in a cycle something isn't telling it to keep dropping to make some heat. For your second question which I have thought myself it there isn't enough air so I do have to agree with you 100% there so I have adjusted the trim and I do wait 15 minutes upon adjustment and nothing seems to matter so I wondering if it could be something else my mind it stumped right now.
Ok thanks a lot will check all of these . Have anyone heard of the door leak test of: shutting a dollar bill in the door and if you can remove the dollar bill then the gasket needs replaced ?or is this just a flukeDid it burn up all of the pellets or did the pellets stop burning?
If the fire is going to embers and then burning out without flame, it is most likely that there isn't enough air. When that happens, most often, the proof of fire temperature is not maintained. The stove should then stop feeding pellets and go into shutdown mode (generic behavior).
Possible causes are:
- air bypassing the firepot (high probability)
- door leak (some air leaks are not enough to trip the vac sensor but enough to compromise burn)
- blower gasket leak
- The list is long...
It's real. The bill should be difficult to pull out but not impossible to pull out.Ok thanks a lot will check all of these . Have anyone heard of the door leak test of: shutting a dollar bill in the door and if you can remove the dollar bill then the gasket needs replaced ?or is this just a fluke
Does your stove have a "fan speed trim" ?
I have a PelPro and I was screwing with the "fan speed" and it controls the exhaust fan - too slow and it will stop feeding pellets.....
Might light fine for a while but as the stove gets hot it seems to require more fan speed or the pellets stop feeding....that was my case.
ItDoes your stove have a "fan speed trim" ?
You nailed it that's exactly what it's doing so to make the fan speed faster ? I'm afraid I'm going the wrong wayDoes your stove have a "fan speed trim" ?
Just so I'm getting this right I adjust the trim to the left for a faster exhaust?Yes fan speed faster by adjusting the fan trim - which adjusts the exhaust pipe fan....not the fan that blows over the heat exchanger
Just curious what works best for your pellet burner when it comes to the trim? I know that we are living in different places so its going to veryActually it is at 0
