scotthershall
Yes, the stove will allow it but the prevailing opinion among 25-PDV users on this here forum is to not run the blower on a lower number than the feed setting/heat range. The thought is doing this reduces over all efficiency by sending more heat out of the vent pipe rather than into your home. The faster the blower blows the more heat is removed from the stove and blown into your home. For what it's worth, I keep my blower on 9 at all times, regardless of the heat range. Running the blower on a lower setting will certainly make the air blowing out warmer but the over all quantity of heat will be lower. I haven't actually tested it with thermometers and stuff, but it seems to make sense.
I also used to have problems with the pot filling up with pellets. After much searching I found users around here are blocking the holes found below the wear plate temporarily with steel wool or in more permanent ways. Here's what I did to solve that issue: https://www.hearth.com/talk/threads/englander-pdv-25-steel-wool-mod.151866/page-4#post-2047220 From another post of mine from last year: "From my research around here I found out that those holes (and the corresponding ones above the wear plate) allow additional air to move around the fire. This lowers the stoves overall emissions by allowing clean air to move around the fire and go out the vent. Essentially, this leaves more soot in the stove as opposed to exiting the stove via the vent pipe. This design allows the stove to pass EPA testing. Plugging those holes forces all the air through the wear plate allowing the pellets to burn completely. So give that a try if you'd like. You'll probably see a night and day difference just like I did. With this modifications, even the Green Supremes burned pretty well."
As an update, my quarters and stove cement are holding up fine.
So, if you haven't already, I'd give that a try.
@Pellet rick - After going through those old posts just now, I noticed you also were involved, so I'm sure you know all about the stuff I was talking about. So never mind! I'll leave the info here in the hopes that others looking for solutions can find it and use it.
Scott
