Interesting twist to this problem.
I took off the back of the stove and realized that I had not moved the damper from the 50% position on the combustion blower motor. Friday I removed the damper completely. Burned two nights now and while the burning was better the first night the right hand side was still not as good as the left hand side with regards to the amount of ash that was being left behind. Yesterday I shut the stove down and cleaned the burn pot and removed a couple of small clinkers. I noticed that while the stove was burning Friday night that it looked like the fire pot was not quite straight...It was not that far off but a bit. It looked like the right hand side was closer to the front of the stove then the left hand side. So I did my best to align it properly and then started it back up. This morning I noticed that now the RIGHT hand side of the fire pot looked like the left hand side did almost completely void of ash while the LEFT hand side had the same ash build up that the right hand side had the previous night
I also noticed that the alignment was NOT as good as I thought it was before I started the fire and the left hand side of the fire pot was now closer to the front of the stove.
This leads me to believe this...The alignment of the fire pot is either not allowing the air to flow equally to both sides if it's out of alignment to one side or the other AND/OR perhaps one side of the fire pot is getting more pellets because of this slight alignment difference. This is crazy! I cannot think of any other reason why this would happen and the only thing I did was change the fire pot positioning and added the decorative logs (which really should not affect anything anyway because they sit on top of the burn pot and do not affect air flow or shouldn't anyway).
