Can you explain why its impossible to go straight up from the T 4 vertical feet then 90 out? Lets see the whole room...
That sounds like an easier solution, the problem is I am supposed to have @ least 3' vertical rise for draft purposes, and I don't ... I have more like 6".The cap is how simpson designs them now, I haven't had a problem with them causing back pressure issues in a properly sealed and vented installation. I'd replace the section that has a joint within the wall for sure and make it so the cap extends 12" or even a little more from the siding on the house.
Merr told me that if you fix her stove piping up she will make you a dinner of your choice....could be well worth the trip..If you were closer would take a look to see if I could give you some ideas. I am on the coast and not sure where you really are except western maine.
And yes I would gladly fix anyone dinner that fix this pos. Interestingly, we turned it on last night bc it was really cold...and tonight is supposed to be 15 out, so we will turn on again I am sure...Anyway, no smoke smell. No clue what's different.My local expert says even if you can use 3", install 4". Reasoning: Soot builds up in the flue and can reduce a 3" pipe to 2-1/2 inches or less. A 4" pipe with the same buildup would still be over 3". It's not that much more money. It's also easier to clean if you have elbows to get around.As far as flue diameter, your stove manual will usually list a preferred and max size, such as:
flue: 3" (4" maximum)
If installing a new flue, I would choose the preferred size, unless that size is going to preclude a possible future replacement of this stove with another.
One thing I noticed is that I can't see any silicone where the vent pipe adapter fits onto the stove. That's the one place where you have to seal with silicone.Hi all I am stuck right now in a position where I am not sure if I need to replace all the venting, or if I could use some of the existing material and maybe just get a new pipe to go from inside to outside that extends beyond the exterior wall, ant a new vertical rise pipe section. (And of course seal it off well ) I am not an expert on this stuff by any means. I tried to get advice from local installers today but that was a no go. It's just that the vent pipes are pretty expensive, so I only want to have to fix this once. My husband thinks that we might need to actually center stove on hearth pad an change where it is going through the wall, because there is not even proper clearance from the interior wall to the stove. However, that seems like it would then require changes in where the pipe goes through the wall, which won't really work. Anyway, if anyone has any thoughts on whether I can use some of what is already in place, let me know. Also, is home cheapo the place to buy materials, or is there somewhere better? Or should I hire someone to fix this for me( which I'd rather not, but if I have to because I don't really know what I am doing I will) . And by the way...I am a she. And if it helps at all here are a few more pics.
