pellet stove gases
So far I have been doing a lot of research. But I do plan on getting everything up and running by spring. This should help to give some idea as what I am going to do.
(broken link removed)
(broken link removed to http://www.valcent.net/s/Home.asp)
very ambitious - good for you. Where does the pellet ash come into play? (why?)
It isn't the ash that Roy wants, it's the CO2 in the exhaust, he is going to suction the gases out of the flue via the ash clean out on the tee.
Remember to watch the Ph levels as that ash will change it if used in quantity.
I add mine to the compost pile.
I know I have some challenges to the system. The air temp leaving the chimney is 400*f (204*c) and I am thinking of installing a inter-cooler or a transmission cooler before returning the air back into my work shop. The temp out side is 5*f (-15*c). It is going to be about matching the system with the amount I would want to grow. I wanted to have the system up and running before summer. I want to start small and work my way up. I plan on using an old small air compressor and have the suction system hooked up to the chimney with the cooler in between. The bioreactore will be about 140 gallons (528 L) system. Later I will hook up a dryer.
Then when the algae is dryed. I will run it through a oil screw press. Extract the oil for a diesel generator. Use the pellets for the pellet stove.
