Greetings All,
My wife and I are looking into buying a pellet stove after our second year using central heat.
After looking around a bit, specifically about installation I keep hearing about a 2inch pipe that needs to go from the stove to the outside to pull in outside O2. Is this true, and if so, do ALL pellet stoves require this? If not can you give me an idea on which ones don't require the outside line?
Also, the existing flue that I have is about 9 feet off the ground, so if the pipe comes out of the back of the pellet stove it will require 2 90 degree turns (one to go out and up from the stove and then another to go from the pipe into the flue). Will this provide good venting or will I be required to by pellet stoves that have the venting come from the top (thus only one 90 degree turn)?
Hope this makes sense and I can't thank you enough for helping me with this stuff!
-Bryce
-Bryce
! :cheese:
