- Nov 15, 2012
- 25
Sure do.You could add a clamp at anytime. If the used a pellet vewnt brush which is soft nylon, I doubt it would wreck the flex. But it would stress it enough to make the sealent leak.
Only way I know to find the leaks is with a bright light while its just starting(smokiest). If its smoking that bad, I would say you should be able to see whereits coming from. Otherwise don't run it until you have the guy come back to fix all the leaks. Make sure he runs it while he there.
Do you have a working CO detector in the home?
I'll add a clamp and see if that improves things. For some reason it seems to be coming from the right side of the machine, but smoke is tricky to nail down. I'll keep trying anyways.
