Can I put a pellet stove on an interior wall?
We have gotten rid of our oil fired boiler and are just using a heat pump. while that works well I'd like to have a second source of heat. My thought was to get a zero clearance pellet stove and cut an opening on an interior wall that backs to the boiler room. Finding a zero clearance isn't the issue but finding someone who has the knowledge to tell me this is a bad or good idea is. The boiler room is a concrete floor and chimney is accessible, the pellet stove would sit in the same foot print as the boiler did. I'd add some type non combustible flooring under the stove. on the back side rather than leaving everything exposed I would build a removeable enclosure per minimum clearance specifications probably out of cement board and steel 2x4
Thoughts? & thanks
Thoughts? & thanks
