F4jock
Igniter compartment is under the burn pot. Cool down and vac it our good. Also, unplug the stove when so doing and leave it so for at least a minute. Did you clean the ESP?
That won't hack it. As Bio said above. "How many tons?" Ya gotta dismantle some things to clean it properly.I just vacuumed in the combustion area. I didn't take anything apart.
Ooooh ! Well you haven't cleaned your stove yet.I just vacuumed in the combustion area. I didn't take anything apart.
X 259Ooooh ! Well you haven't cleaned your stove yet.
Joe Don Looney?If you have not gotten past the ash bin in cleaning, your stove is probably choking on ash etc in the exhaust pathway, the ESP is covered and not reading properly and the hole out thru the ash in the venting is probably the size of I think you Canadians call it a looney. You have some serious work to get things working properly and safely. IMO
In a word: YES!
I always find a glass of Cabernet helps the cleaning go down.Translated into Pellet Head "Clean the blasted bucket of parts correctly, take two asprins, and call Bioburner in the morning."
I saw what you did there.
Due to a very high number of calls this number has been disconnected and owner has moved to where they do not know what a *&%# pellet stove is.call Bioburner in the morning
Listen, you got to clean it all ! If you had one full ash pan it's time, never mind if you have had several. This is not going to be 'I'll brush off this little piece here and all is well, up and running". And then you need to get into a routine. I think in an XXV you have baffles to be pulled out. I know you have a hatch behind the ash pan when removed you have a through path to your venting. Be careful in there, look with a light, your ESP probe is in there, don't wreck it ! It's best to pull the ESP, then you can clean that too. You have the igniter chamber to do, the fines box to do. Don't forget to brush down the combustion blower fan. And you probably need to brush out your venting. When all that is done let us know how the stove runs. This should take maybe an hour on your first whack at it. You should have lively flames and dancing pellets in the pot. Oh don't forget the holes in the burn pot, give them a little ream job while you're at it.Well could the venting area affect the flame?
Of course it was, read aboveJust emptied the fines box. It was plugged. Let's hope this works
Great start! Now do the restJust emptied the fines box. It was plugged. Let's hope this works
Good, set your feed rate at 4.Well I've done all of those, just turned it on now so we will see if it lights
Gotta plug 'em in. . . . . .Those Harmans take to damn long to fire up.
if the Igniter worked before and you just cleaned,[usually you pull the ash out with your finger as lot's of dried ash in there]Seems as if the auto ignite won't work. I started it manually with gel. But it will probably die out again
