Check this out for suggestionstundraSQ said:GVA said:If you do a search here I'm sure you'll see tips on what to use to scrape the burn pot with, as that scraper that comes with the stove is ok for removing ash but not clinkers(carbon buildup). Use the scraper that came with the stove for walls and heat exchangers but the burnpot needs something a bit more rugged.tundraSQ said:TedNH said:I got my stove figured out.
SCRAPE YOUR BURN POT.
And I mean GOOD.
I had big chunks of carbon stuck to the SIDES of the pot. Now the fire looks like a blow torch and its throwing some mean heat.
I just did this..I had been cleaning the front of the burnpot....tonight I let the fire die down and REALLY got deep down and cleaned it all out...I had no idea the back and the sides would need to be cleaned. This is a learning process...but I ran the stove for 2 days without touching a single setting...
thanks
Just a tip Every day when I get home from work I give a quick but strong scrape of the back of the burnpot, Just to keep the carbon from really building up (it only takes a minute and the stove is still running when I do this)
On the advance the major buildup is always on the left hand side of the burnpot and the glass always fogs on that side first.
There seems to be a bunch of 25 owners here.... What side is worse for clinkers and which is worse for the glass fogging up?
Left side for me had the most build up...and I was thinking as I was scraping it..."there MUST" be a better tool for this"...and the right side and top of my glass fogs worst.
https://www.hearth.com/econtent/index.php/forums/viewthread/3523/
