Pellet burner using too many pellets!
Edwardface
4
Sweden
Hi everyone, I hope somebody can help. I have a pellet burner (ep-18a - https://www.altbergsplat.se/produkter/pelletsbrannare) and it's burning too many pellets. I'm getting through 3 X 16KG bags per day.
The pellet burner is attached to an ATMOS DC30SF wood boiler. It connects to a borö TIV 500L/FC110 which itself attaches to another TIV-500L. There is a Laddmoat 21 in between the boiler and the tank that I have replaced the thermostat valve on.
Something must be wrong somewhere as we're not even using it to provide us with hot water, it should only be being used for the radiators but it never stops running.
I have set the temperature on the boiler to 80ish and the pellet boiler does switch off once it reaches that, but only for 240 seconds which is set on the pellet burner and cannot be changed. It then fires up and runs for a while, rinse and repeat.
The pipe that goes up to the expansion tank in the attic is very hot (70 degrees Celsius at least), so it feels like instead of switching itself off it just keeps on going and going, which heats the water in the expansion tank in the attic.
I have tried connecting the boiler to a timer switch so that it is on for 2 hours then off for 4 hours, but even that is still using 2 bags per day, and before those 4 hours are up we can feel the temperature dropping.
I have a neighbour who i spoke to about his pellet burner and he uses 3 bags a week, and he also uses it for hot water so there must be something wrong. Any advice would be great. At the moment it's costing us $24/269SEK per day for heating.
  • [Hearth.com] Pellet burner using too many pellets!
Welcome to the form
Wish I could help but I have never seen or heard of your burner
To you have a manual or can we get one online then maybe we can help
or maybe we have someone here who knows your unit good luck
Is your attic within the insulation envelope or are you loosing all that heat there?
And how does that compare with the set up of the neighbor?
I.e. can this explain the high usage?
(I don't know pellet systems well,.but this is what stood out to me.)
Regardless, insulating it with some (significant) insulation, including the piping,.is likely worth the effort.
Understood.
I just wonder where the triple BTUs (or kWs) are ending up if you're not roasting out of your home.
i guess you should compare settings and equipment with your neighbor and see where the differences are. To me it seems that thair are to many pc's in the mix and your going to have to go play with the settings of each. Im guessing the pellet burner has its own settings and that is where i would start. Not alot of information out their on that system.
Reactions: Ssyko and johneh
Did you do the install or was it done buy certified tech’s ?
Reactions: johneh
@zrock I will compare the differences but the trouble is that his setup is completely different. Different boiler, different burner, he doesn't use accumulator tanks. His system was built for a pellet burner whearas mine was build for a wood boiler, and has had a pellet burner slapped on the front. @Ssyko It was installed by a "professional heating engineer". Unfortunately he doesn't work for a company, he just does it in his spare time. but he thinks it's completely normal for the burner to be going 24/7, which is completely insane to me...
Edward im sorry but I can’t find enough info in english to be of any help. I would try calling the company that designed it and ask for help.
