Where are the other Maine Energy Systems Bosch Janfire owners posts? Freefromoil is here, but there have been no other posts. I've heard some of the challenges that others have dealt with through some conversations with other installers.
Our 4-Section Bosch Janfire unit was installed on November 18th. The 5/6-month wait was full of excitement and anticipation. The process of making the decision to purchase the Maine Energy System, to waiting for delivery and then getting the installation completed had its highs and lows. A lot could be learned. Our installers came with a great attitude and we all knew there was a learning curve ahead of us. The system required some tweaking adjustments to maximize the heat output etc. We were taken back by some of the installations quotes we received and even questioned our decision when oil prices plummeted. In an earlier posting I stated that I had turned down a Tarm 4.0 installation for $12,500.00. Cost of adding heat storage (very high) and no large bin took the Tarm off my list. In reality, everyone has to make a decision with what works within their budget. The Maine Energy System offered some options (the features) that we put more of a priority on. The features that we coveted were to have in indoor system that also had a large bin for weeks of sustainable heat instead of just a hopper for heating a few days to a week. At the time, Harman was the only other system to offer a large ton capacity bin. In some ways, I regret that I passed on a great season-ending price for the Harman last May. Posts within this forum regarding lack of support from Harman chased me away. In retrospect, the Harman's ash pan may have been the easiest to facilitate emptying. The MES system has no ash pan and ash removal must be accomplished more often than the "marketing/selling claims". Removing the ash from the MES system is easy enough to do, but should probably be accomplished every ton of pellets burned.
We have a 50+ gallon hot water storage tank and a 4 ton pellet bin alongside. Because we ordered 8 tons of pellets last May/June we have not had to use the bulk deliver feature. Pellet prices are too high right now
![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
In about an hours time my wife and I moved a ton from the driveway to being stacked and stored in our basement - really simple. Not a lot of fun, but it really wasn’t very hard or laborous. We used a slide to shoot the bags down to the basement. If given the choice between lugging 40 pound bags of pellets or cutting/splitting/stacking mega cords of wood, we made the right choice to go with pellets. There are now other pellet boiler systems available: Woodpecker, Pellergy, Froling, and the few that we had to select from: Tarm, Pinnacle/Traeger, Harman, Orlan, and MaineEnergySystems. If I omitted a unit - sorry.
A key point to mention is that our 4-Section Bosch Janfire is actually "undersized" for our home. Once the system was tweaked to maximize output, I assure you that during the week or two of sub-zero and sub-freezing temperatures the unit kept the house plenty warm. Our oil boiler was very old, so we have no backup support, but didn’t need it. See Dutch Dresser’s blog link at the top of the MES homepage speaks to having his oil burner kicking on for backup during some of the coldest days of this season. We've experienced some of the same issues (Ash Scrape and a blown fuse). Get a package of fuses with installation.
THE ONE issue that really caused us frustration was the system kept shutting down when the water pump kicked on. It took "WEEKS" to troubleshoot because it didn't happen all the time. When we lost power during the ice storm, I was able to isolate it because we were on a generator. The well pump and pellet boiler cannot be on the same side of the circuit panel. The extra power draw when the water pump kicked on caused the unit to fault and shutdown.
More could be done to support the installer/customer by communicating "lessons learned" on the MES website.
Below is Freefromoil's response.
In mid-November we had a professional install Janfire/Bosch 6-section boiler. We live in Central Maine and had a qualified MES installer who has been awesome. If we hadn’t had a dedicated pro who was willing to work really hard to perfect the install and settings we would have been sadly disappointed with this system. It is our single source of heat as we tossed the leaky old oil boiler to the curb. We have had a few bumps here and there, but have been satisfied with the performance.
This is our experience so far:
5 tons burned since Nov. 15 in a 2500 sq foot drafty farmhouse.
3 pellet deliveries at 2.75t each. I would estimate our bin holds 3-3.5 tons they had to cut it down to fit our ceiling height.
60 gallon hot water storage Top Performer indirect set to 135 dgrs= nice warm showers
Weekly ash cleanings (don’t believe the once per season cleaning on MES site)
Nice warm house (we even left the house untended for 4 days at Christmas without problem<risky thing to do, but nothing shut off)
Problems:
Constant Ash Scrape error from Janfire NH burner (solution: reduce amount of time b/w ash scrape and clean slag on burner we found a tiny piece of copper lodged under ash scraper left by install and were able to remove it)
Overtemp shut down (boiler and burner have seperate temp controls and the boiler overheat at 240 degrees cause system shutdown / we were able to prevent this by reducing the janfire burner settings so the burner would not overshoot the 180 degree mark needed/ burner setting low 140 high 165/
Blown fuse (keep a few extra fast blow fuses handy in case needed as the heating coil inside burner can cause blown fuse at start up, we have reduced the stress on this by increasing burner standby time to 30 minutes so that a tiny flame will stay lit between calls for zone heat to avoid inefficient short cycling of burner)
After working out these few kinks things have been running smoothly.
Ten things you should now before install:
1 This is not maintenance free system
2 Someone should be home daily to ensure warm house
3 Your basement will lose a lot of space
4 Plan week ahead for fuel delivery
5 Keep some extra bagged pellets (just in case)
6 Much better than filling a wood stove
7 Same price as oil
8 Your home will be heated with a carbon neutral renewable resource
9 Awesome for the local economy
10 You can laugh when you see the oil truck go by that cost you 4500 dollars last year
