I appreciate all the help I've gotten from this board. We're still trying to decide on a wood stove. After reading about all the maintenance cast iron cat stoves require, we're a little leery about one and are considering plate steel instead. I've read alot of good things about PE's Summit on this board, but I'm wondering if it would be too big for us. Our woodburner (currently an older Earth Stove) is in our basement family room (13' x 15'). We have an open stairway where the heat comes upstairs to our main living area (approx 1100 sq ft). The intake for our furnace is directly across from the woodburner, so we run the furnace fan to circulate the warm air and also use a fan to blow the air upstairs when it's really cold. This set up has worked fairly well with our Earth Stove. We burn it 24/7 and only use our furnace during the time we've let the fire die down enough to take the ashes out of the woodburner. Our bedroom is directly over the family room and woodburner, so at night we shut it down to a low burn. Otherwise, the bedroom gets too warm.
I've read several posts on this board that say a bigger stove is better and that it can be shut down to a low burn. We don't spend much time in the family room where the woodburner is, so we keep it pretty warm in order to heat the upstairs. What I'm concerned about is that we might have a problem controlling the Summit and keeping it burning low enough for it to be safe in a 13' x 15' room. Is the Summit easily controlled?
Thanks,
Jan
Thanks,
Jan
