Maybe a Napoleon 1900 in the future?
No problem, something in the 3 cu ft range.
It depends on the house and area of installation. They are quite different stoves. The T6 is convective and the F600 is radiant.
This is a tough call. I want the "perfect" stove this time! Cant afford to do this again, plus the government money will likely be up soon. Ive been thinking and wanting this upgrade for 2 years now! Time to get off the pot...You can load the T-6 N/S. End of discussion. PE put the side door in the front of the stove.![]()
Jotul - 1, T6 - 0. I'm not impressed with the small ashole that the T6 has.What about Ash Pan on the Jotul vs the T6? I understand the Jotul has a very nice system. I want to get away from the bucket and shovel and the dust it creates.
With N/S loading in the T-6 it is just like side loading another stove. Tight pack, no roll outs to the glass. All blowers blow air up through the rear heat shield. Same same any stove you buy.
. I want something that makes the air hot like that.On ash pans I have only one opinion. They are all crap and I let them fill up within two burns and never use them. Except on my current stove. The only time I use it is to heat dinner rolls since it has never had ashes in it.
Learn to scoop ashes right.
Yep. Do it when the stove is still warm so the flue is drafting. Hold the bucket leaning into the door and gently scoop and put them into the bucket. The draft pulls the dust up the flue. If you have coals in the scoop shake it gently and they fall off and you move them to the side for the reload and then dump the ashes gently into the tucked into the door bucket.
. I hate wasting alot of those hot coals, but I have to get a them out to make room to reload. The firebox has a low ceiling. Thats another part of the reason I want to go biger.![[Hearth.com] PE Summit vs. Alderlea T6 vs. Enerzone 3.4 vs. Jotul F600 FL vs. Jotul Carrabassett [Hearth.com] PE Summit vs. Alderlea T6 vs. Enerzone 3.4 vs. Jotul F600 FL vs. Jotul Carrabassett](https://www.hearth.com/talk/data/attachments/121/121075-3f77c7288f82b0c277ae9f0680eb4938.jpg?hash=Io_o0ucxKh)
Every house, stove and split you put in it is different. I don't have a T-6 or live in NS but have a stove with the same size firebox. And at the moment it is 26F outside, 74F inside upstairs and down in this 2,500 sq. ft. barn and this night burn is settled in to keep it that way till sunup. With the blower running.
