you might want to drill stop the cracks before they get anyworse if they dont cover it before you buddy welds them up.
Ray
Ray
Sisu said:Like you said Hog, I too run mine fairly hard. 24/7 for almost all of the fall/winter/spring seasons. But there should be a difference between running hard and overfiring. It is a wood stove insert. It is not for decoration (even though it looks nice) and is meant to have a fire in it and produce heat.
Are you going to still run yours as is or shut it down for now? The cracks along the upper door openings are the biggest concerns, since they are allowing air to pass into the firebox and could allow for hotter fires. I am not running mine now and took the baffle, bricks etc out. It is going to be +3 degrees Celsius (37.4 Fahrenheit) tonight.![]()
Burning Sensation said:Is there an over firing temp listed in the manual? If not then then I think you are ok saying that you never over fired it according to the instructions.
BrotherBart said:If they deny the warranty claim, take them to court There is nothing in the PE warranty or manual that could ever win.
Not to mention that it would be cheaper for them to replace your insert than to fight it in court.
Sisu said:Thank you for your replies. I contacted the dealership headquarters today in regard to the cracks in the firebox. The person (who I have been dealing with since the baffle issue) said immediately that the cause is over-firing. He stated that PE has only ever received a total of 6 fireboxes returned, since the start of their operation. However, he had not yet seen the photos.
timfromohio said:I have a PE Pacific insert purchased and installed in 2005 - I'll be inspecting very carefully this weekend. Let's keep this thread going and post whatever is heard from PE.
Hogwildz said:BrotherBart said:If they deny the warranty claim, take them to court There is nothing in the PE warranty or manual that could ever win.
Is that even realistic. What kind of suit? Small claims?
BrotherBart said:If you need to be bailed out, I will be on the way.
