No I don't expect this. Full air is just for starting. Non-cats burn best when the air is turned down. This makes the draft pull air through the secondary. If it was at a single high burn rate a lot of heat and emissions would be heading up the flue. What's being tested now are automated controls that sense several parameters to determine the stage of burn and adjust the controls accordingly. This is an early work in progress.Do you think that most non cats will just go to a single (high) burn rate? Non cats tend to burn a lot cleaner when burning on high.
