- Nov 27, 2012
- 0
Question:
My question concerns the credibility of my general contractor. When drywalling and painting the home that I am building his subs got the fireplace vents and frame covered with drywall and paint. He says that he is going to paint over it and that it is NO BIG DEAL
MY question is should I be satisfied wth this (he claims that this is something that happens all the time). I am wondering if I should be demanding A new fireplace to be installed or if that would be over- reacting.I know that there is heat resistant paint for this but if it was you would you be happy with his answer and solution. What about down the road and what about appearance? Please answer me as if you were the one buying this house
Answer:
Those vents are not really painted with anything too special, so regular heat-resistant (BBQ type) paint or stove paint will surely do the trick. Not a bad idea to clean them will first with a little fine steel wool. Then they'll be as good as new.
I don't think a new fireplace is needed at all, since these parts are usually simply spray painted at the factory also.
![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
Answer:
