LowbanksArcher
Did you get some larger splits of wood? If yes, how large?
With the extreme cold weather you are experiencing, draft is probably quite strong. You may need to reduce draft and/or air going to the fire. I would start by blocking off the boost air port with a magnet and consider putting in a key damper into the flue pipe. But that may not cure the issue if the splits are more like kindling size.
I've foil taped the boost hole and gap left from the main air. It's behaving quite nicely today. No wind. I'm just incredibly disappointed in the air leakage through the ash door on this $3000 stove! If I don't pack it down with ashes, it pulls air like crazy. Poor design as far as I'm concerned.
This is what I'm burning. It's been in my woodshed for almost 2 years.
![[Hearth.com] Pacific Energy Summit air control problem [Hearth.com] Pacific Energy Summit air control problem](https://www.hearth.com/talk/data/attachments/174/174968-2416af93fde07fd11c9541db98287d61.jpg?hash=KumyPVx91F)
![[Hearth.com] Pacific Energy Summit air control problem [Hearth.com] Pacific Energy Summit air control problem](https://www.hearth.com/talk/data/attachments/174/174969-180bee6525150477abcc8c7a52064bc0.jpg?hash=Xw7JHMi9wH)
![[Hearth.com] Pacific Energy Summit air control problem [Hearth.com] Pacific Energy Summit air control problem](https://www.hearth.com/talk/data/attachments/174/174970-993771f8c809a021c4f36195a2f1e6d0.jpg?hash=BI9BI94sBv)
