Hello,
I have a PE Alderlea T5 insert that was installed new in December of 2015. Unfortunately I cannot find a picture of the back plate to get a serial number off of or a specific manufacture date without sliding the stove out.
My question ... Does anyone know if this has the original EBT in it or does it have the EBT2? Has anyone seen these fail or need replacing ever? Im wondering if mine is stuck in the closed position.
Typically I have always been able to run the stove on its lowest setting and have jets of flames shoot out of the baffle during stage 2 of the burn. See link to see what I am referring to as stage 2 if not familiar.
The past few nights I have loaded wood that has been stored in my garage for 2+ years. Moisture meter read slightly less than 10 percent so it is not a wood problem. I replaced the baffle gasket with a PE gasket so that is brand new as of 3 weeks ago.
Is it possible that the EBT is stuck in the closed position and not getting air up top when the stove needs it? We did not use the stove last season as we were in the middle of a whole home renovation and not living at that residence. The stove was kept inside during the construction phase but was not kept in conditioned space for close to a year.
From what I am used to the stove is not putting out as much heat as before without the secondaries lighting off. When putting in a fresh load of wood in years past I have always been able to get it to burn front to back, like a cigar would burn, while having the secondaries fire off during the whole stage 2 of the burn. and then slowly dying down once the gas from the wood is consumed. Now I am not getting that. The wood just burns in no really predictable way, and a lot of the time I have to bump the air control to 1/3 open to get any meaningful flame out of it and to get the secondaries to fire off any.
Anyone with any insight? My local guy who I bought the stove from has since retired and sold his business to an HVAC company who has little to no knowledge of these stoves and how they work. I have not tried contacting PE directly yet as I usually come here first to look for answers.
Thanks
Sweep's Library - Pacific Energy's Extended Burn Technology
Here's a look at Pacific Energy's EBT technology, as used on several Summit, Neo and Alderlea wood stoves
hearth.com
Thanks
