P61 Harman pellet stove
  • Best
    Votes: 1 100.0%
  • Most
    Votes: 1 100.0%
  • Total voters
    1
no i havent touch the feed rate or took it out of stove temp i just turned up the heat setting a little to like 65 degrees not bothering pellet feed no more lol
You're starting to get it. Little adjustments in the temp at a time. If the stove is real hot when you turn it off, it will feed pellets and slowly work the temp down. I've seen mine feed for a half hour after it was turned off.
Thats great to hear my first floor where we sleep is about 600 sq ft and the same up stairs we mainly use a heat pump but electric is getting so high and not as warm thought we would try something little different got this stove for $200.00 so it was worth trying and with u guys i may make it thanks again !!!!
Get you're room temp mode working and you'll be quite happy. The key is keeping your stove clean and finding a pellet that works good for you.
