You have a leak in the exhaust piping or where it connects to the stove tail piece. Maybe with the stove snuff the fire out to get it to smoke and shut the door and be ready with a flashlight and look for smoke. Should be easy to spot the leak
the other thing I just thought of is dry ice like people use for holloween decorating to make it look like a smoking cauldron put it in a bowl with warm water and place it in the cold stove and start the comb blower. You should be able to spot the leak with that I would think. I know they sell dry ice in our local Meijer groceryoohhh... ok that's neat! while not running - start it up and let it smoke/smolder. and look with a flash light!! cool! So straight forward, and when you get in to the weeds of trouble shooting something you don't think think of the steps!
Air intake flapper moves freely? This does sound like low air to fuel, check that your OAK is free as well
did he clean and brush the entire chimney? did the combustion blower get removed and cleaned? if the chimney was full so is the stoveOk... chimney dude came.. he was like... wow.. yeah your chimney is wicked caked up... espicially up at the cap.
So I didn't have good airflow there.
+1... If the chimney was 'caked up' the stove is really wadded up.did he clean and brush the entire chimney? did the combustion blower get removed and cleaned? if the chimney was full so is the stove
Here is a photo of your intake, flapper is insideintake flapper? Where would I be able to see that?
could the board be to blame for improper air to fuel? (I would expect that this could also throw off the ESP probe and cause it to also throw an error)
not using an OAK - just direct from room.
Harman # 3-20-06142E is on your board..
Same company....Or try calling them to be sure correct before purchase, looks like it went thru some number changes![]()
Harman Control Board 3-20-00928, 3-20-05378, 3-20-05890, 3-20-06142, 1-00-06142 | eBay
Updates: The new style Harman board does not use the J2 sensor. Harman Pellet. Harman Wood & Coal. Installation: Dip switch settings on the circuit board must be set based on the model & ESP Probe Wire Color prior to installation.www.ebay.com
While doing these test I assume you did have the ash pan door and stove door closed securely?
