The house temperature swings during the night are a nuisance to a good nights sleep. This rascal (Uponor 3-way) could very well remedy the situation. Yes? The objective is to level out the temperature peaks and valleys that occur while under the covers. Is installing this unit and running the circulator 24/7 going to reach the objective?
This Uponor (Wisbro) valve uses the outdoor reset feature to control the mixed temperature. Model A3040075 3/4" or A3040100 1". It has a maximum water temperature of 240F and a reset ratio range from 0.2 - 2.2.
This unit does not appear to use the indoor house temperature in its equation. Is another controller required? Or, Is there another unit that does double duty? Anyone using another add-on unit to achieve steady house temps?
