It looks like the best place for a thermometer might be on the face above the left or right door corner.
Yes the auber thermometers are what we use typically they have a screw on sensor a probe and a magnetic one for inserts we usually use the screw on one but if you want stove top measurements you could use the magnetic one and slide it into the opening so you got an actual stove top measurement. I prefer pipe temps over stove top temps personally but either will work fine for your stove. Or do what bg said with a simple magnetic thermometer. The benefit of the auber is it has an alarm you can set for an over fire.Still I'd like a thermometer. What's the deal with a remote flue thermometer ? So I'd have to remove the liner and stick the temp reader on the inside of the liner ? Sounds like a pain to do. Does anyone make a thermometer that attaches to the outside of the liner and uses wires so on an insert a person could run wires from the flue to outside the surround where the temp guage can be seen ?
We get them up as high as we can 18" is optimal but we usually can only get about a foot. If it is lower it will just mean that your temps will be a little higherBholler. On the inserts whereabouts do you guys mount the ring? At the flue collar?
no because we use heavy wall light wall it could be an issue.You just screw through the liner? No issues with doing that?
It shouldn't it should be attached with a band clamp or with rivets backed up with washers. If you have light wall I would screw the sensor to the adapter.It's got screws in it attaching it to the appliance adapter which look ok
Well it is not right. But it will probably be fine I would just pull the face plate every couple years and make sure those screws are still tight. If they start to feel loose I would then get the correct adapter and switch them out.Well mines got screws holding it in place. I didn't install it myself I assumed it was ok. Should I be concerned ?
Yes everything looks fine as expected. But I am glad you checked now you have that piece of mindHere's a picture after pulling the face plate all looked good to me ? No damage from the over fire and screws look to be ok
That liner doesn't even look like been very hot yet. Typically that close to the stove it's discolored.View attachment 188127
Well mines got screws holding it in place. I didn't install it myself I assumed it was ok. Should I be concerned ? Got a few cords burned through it no problems at all. Here's a picture after pulling the face plate all looked good to me ? No damage from the over fire and screws look to be ok
Every stove flue collar is different. Often the appliance adaptor/elbow needs trimmed to fit the stove, so it fits flush.Bholler and Webby thanks for all your input. It's very helpful and I've learned a lot about the do's and don't's on this stuff from this website.
I can understand why screws are not ideal. I have no idea why the installer used them? I also thought that adapter should fit more flush with the stove but that's as far down as it goes. I hate to create more work for myself so since you guys think screws are ok for now I'll leave it as is.
Also good to know that you think the liner looks like it's not been that hot. I thought I cooked it the other night but I guess my perception on a real hot fire is not accurate.
On that note, not having a thermometer yet, do you guys feel one can guage safe operating temperature by the flames ? I've just assumed if I have a rather "slow" flame and slow or lazy secondary combustion that I'm burning in the correct temperature zone. If flames go out then too cold. If flames are roaring and blowing like in a windstorm then too hot. But a lazy flame about perfect. Is this good thinking ? Especially without a thermometer ?
Most new stove owners don't really know what hot is. That's kinda why I figured you weren't all that hot. No offense.![]()
It's probably ok. I just like things a certain way, no gap is my goal.No offense taken. I'm glad you were right in that I didn't overheat my stove and liner. And I'm thankful for this website lots of great info here.
So your saying the adapter should probably have been trimmed down a bit ? I don't see or smell any signs that smoke is getting out so I'm thinking although it looks odd that the wider portion of the adapter is not flush to the stove, the connection must be ok.
