The chimney suction does add, but it's not going to add one to one. Are you considering pressure changes? Yes, more air flows out the chimney, and it causes a decrease in pressure in the basement, which draws more air into the basement. But that same pressure drop is going to decrease the amount of air flowing out of the upper house envelope. So some of that air that is now flowing out the chimney had been flowing out of the attic anyway. It's not a one to one increase in incoming air.
I don't have the math to calculate it, and it's gonna vary wildly anyway depending on temperature and wind conditions, but I'd guess it's more like a 50% or less increase. Maybe 208-210 CFM instead of 200 CFM. Is 8-10 CFM worth cutting another hole in house envelope for a stove that may not be completely sealed to the indoor air?
But put aside where the air is coming from - no matter where the air comes from, it still needs to be warmed up.
With an OAK, it is cooling the stove instead of the basement walls, but the basement walls are warmed by radiant heat from the stove. The stove is heating the same amount of air. Does it take more energy to heat air in the basement as compared to air in the stove?
I do think that OAK's can serve an important function in certain installations. But maybe not in every case.
