Outdoor Use
Hmm, how are you holding up the chimney, doesn't it want to fall over? Did you fasten the reducer with hardware or cement? Can u include a rear view pic?
Sent from my SCH-I535 using Tapatalk
Sorry, I reread the previous posts. Finally moved it over to the deck and had a break in fire last night. I had the chimney on long enough to test the draw, which was fine. I'm just hesitant for some reason to drill into the stove collar. While refinishing the stove, there was some residue of cement/epoxy around the collar, as if it one of those materials were used?
On another note, the handle gets hot while the screen is on. Is there something I can coat it with to help?
ended up drilling holes.
  • [Hearth.com] Outdoor Use
Sorry, didn't see this until now. I think I have the same residue on the smoke exit - probably furnace cement from when it was hooked up inside a house. As far as the handle, I just coat my hand with a glove and let the handle be hot.
Almost worked all the bugs out. First pot if chili came out well, easy to modify the temperature by moving the pot around the top and adding more fuel.
[Hearth.com] Outdoor Use[Hearth.com] Outdoor Use[Hearth.com] Outdoor Use
Reactions: My_3_Girls
