Out with the old.. in with the new
Going good... as you can see the mortar has dried to be the same color as the original fire place. Props to Czar distributing.. chicopee, MA for a job well done. I removed the fake logs to see if that helps the soot on the glass problem. We will see if that helps. Also, have noticed a lot of noise from the burn pot agitator... so I'm hoping that is just from the break in period. When I run it at heat level 4 or above at regular pellets it is definitely making a very annoying noise.. so I'm hoping that goes away. I read it is an issue with the M55s. The stove is in our living room..so the noise is an issue if it continues, but I'll give it another week before I raise the issue to the distributor.
  • [Hearth.com] Out with the old.. in with the new
They seem to be shipping these units with the chain a bit too tight. Try loosening up the chain a tad.
