Where is the block off plate located?Hardi back cement board, heat resistant and non combustible
How do you plan on replacing it when the cement board starts to deteriorate from the heat and stress of the liner and masonry expanding and contracting?All the way around the bottom of chimney
But the stove doesn't fit out the hole.Easy, it will pull right out after you cut the stainless liner coupler, add a new 1 and put "a" stove back in it.
How it won't fit through the hole. And it needs an 8" liner as well. Or atleast a 7"Realisticly, a grandpa bear with a top flu will go right in there.
You would have to pull the stove forward and tilt it back some and drag it out.
Not a problem.
Not a problem.
But just welding a 6" outlet onto a stove that needs a larger flue doesn't change the size flue that is needed for it to work properly.An adapter for a 8 inch top flu to go to a 6 inch steel liner.
Or just have a professional like I had weld on a 6 inch heavy duty flu.
I already know the answer you previously said you had a family to watch out for. Are they aware of the large number of safety compromises you chose to make with this install?I do see your point. Yes there would likely have to be some masonry cutting on the inside brick edges to pull the stove out with some masonry work after another stove went in
Bholler, I'm not going to answer that.
It can't be pulled out the opening that was built is smaller than the back of the stove. Which is why I repeatedly said this install was unserviceableYea at least get the stove out so that we can look at that fireplace and really examine it...sounds exciting doesn't it--examine it--lol I do have a question what is a adapter? Video would be good but don't fire it up until the experts take a look at it and analysed what you did--easy peasy just pull it out but be careful...By the way after you get this all fixed I have a beautiful wood stove for you to consider buying just for ambiance...old mrs clancey
I only asked because I get that you think this is a big joke and that nothing can go wrong. But is their safety a joke to you as well? I am seriously trying to help you.I do see your point. Yes there would likely have to be some masonry cutting on the inside brick edges to pull the stove out with some masonry work after another stove went in
So you have a layer of cement board then wood??? Great ideaBholler,
Yes, I live with somebody. My boyfriend and I are getting married next month and going to adopt. He likes it on the bottom when the Fisher stove outside our bedroom is cooking nice and warm.
View attachment 281073 View attachment 281074
