The reason I'm asking this here is the heat tolerences are right up the alley of Sandor and Elk. I'm installing a double wall oven. Usually you would have a 30 inch cabinet. I'm using a pantry closet instead. Inside dimensions of closet are 38 inches side to side. only real heat concern is it says you have to have adhesion tolerance for nect cabinet of 194 degrees. I'll be building the cabinet inside this closet out of 3/4 inch plywood. Can you think of any "gotchyas" I might run into?
