Finally finished the install last night and have the second fire going now but it appears I have a pretty significant draft issue. I put in a load of pine (a little over 1/2 a load) this morning about an hour ago and finally closed the door. If I would've done this with my Morso with an equivalent amount of wood I would've melted the stove.
I am at the minimum for height on the chimney, 14' with 5 feet of flue, 3 feet of Class A in the attic in a chase and 6 feet out the roof, all straight up. 10-3-2 is well exceeded. When installing the flue I could feel a pretty good draft so it just doesn't make sense that it is burning like this.
I can add another 2 or 3 feet which will make cleaning a pain but it doesn't make sense that the burn is this bad. The highest stove temp I've gotten so far is 400 degrees.
Any ideas?
Any ideas?
