Rob_Red
Nice tall firebox
for those of us with a lot of odd shaped cordwood that’s a dream!
Nice tall firebox
The 3300 looks very similar to the new Lopi Endeavor, so now you have two options. I’d say the Lopi costs a little more and is made slightly better though that is a guess (yet to see a 3300 in person). I do know the Lopi’s are built really heavy (I own a Liberty). Best bang for your buck is still likely the 3300 and if I were buying new I’d likely opt for saving some money. I wouldn’t be afraid of either choice.
Unlike the 3300 that is said to replace the Myriad (used to have a by-pass, which I happen to like), the new Lopi Endeavor still has the by-pass, a taller firebox and door with bigger viewing area. I think both have an ash pan.
The Myriad is still in production. The 3300 is in the Osburn line. The Myriad III is in the Drolet line. They are siblings, but the Drolet Legend III is closer in design to the 3300. The Myriad is on a pedestal and has no side shields for a less expensive, more radiant stove. Once you brought it up, I found an error in the Osburn 3300 manual for the glass size which says it is 15.75" x 9.75". That is wrong. It is 15 1/2''W X 12 5/8''H.The 3300 looks very similar to the new Lopi Endeavor, so now you have two options. I’d say the Lopi costs a little more and is made slightly better though that is a guess (yet to see a 3300 in person). I do know the Lopi’s are built really heavy (I own a Liberty). Best bang for your buck is still likely the 3300 and if I were buying new I’d likely opt for saving some money. I wouldn’t be afraid of either choice.
Not sure ,you can go to osburns website and lookup parts manual
The only reason I said Myriad is because I thought someone mentioned it in this thread and I wasn’t going to argue with them about it. I know SBI has two, maybe three lines of stoves that are nearly identical except for trim. I knew the Myriad was in a pedestal, but try typing on a phone all the time. The fire box are close enough.The Myriad is still in production. The 3300 is in the Osburn line. The Myriad III is in the Drolet line. They are siblings, but the Drolet Legend III is closer in design to the 3300. The Myriad is on a pedestal and has no side shields for a less expensive, more radiant stove. Once you brought it up, I found an error in the Osburn 3300 manual for the glass size which says it is 15.75" x 9.75". That is wrong. It is 15 1/2''W X 12 5/8''H.
The Endeavor NexGen is a step top stove and a sweet update, but it has almost 1 cu ft less capacity. I don't think the firebox is taller, the secondary rack is lower in the Endeavor than the Osburn 3300. Not knocking the stove. I have a fondness for the Endeavor. The pre-2020 version is a good heater and hopefully the NexGen version will be even better.
One thing you might want to check out when you get your stove is the air control cover.it has 2 holes on each side to bolt to the stove .why 2 I don't know as it weighs nothing.anyways I noticed with mine that if you line up the bolt holes to mount the cover the air control goes way past being closed so you don't know where you are when you want to open the air just a little. What I did is just moved the cover forward and used 1 bolt on each side .now when you close the air control it is right at closed.mentioned this to sbi but never got a reply.hope I made sense lolI just put a 3300 on order. Should be here in the next couple weeks. Again, I have been running a defiant with secondary combustion and a bypass damper to change the flame path. That stove can run wild if not properly operated. Not knowing how modern stoves specifically behave, is there a chance that this stove can run wild also? Would you recommend putting a stove pipe damper in to start or see how she runs? Most stoves don't require a stove pipe damper, unless there is excessive draft from my understanding.
Give me a heads up when you get your stove and I will walk you through itThanks for the info. Marty, it doesn't make sense yet, but it probably will when I get my eyes on it. Thanks for the heads up. Sounds like a key damper isn't necessary then for starters.
