Both have large fireboxes that can load N/S or E/W. They are the upgraded versions of the Drolet Myriad and HT3000.Was there any consideration for the 3500? From my understanding the 3300 is more geared towards NS loading and the 3500 EW loading. What is are the firebox dimensions of the 3300? Do you intend to burn NS? I am considering an Osburn, not sure which model just yet, trying to understand the comparison. Great looking setup you have
The firebox on the 3300 is 3.3 cu ft and the 3500 is 3.5.the 3500 only comes with a pedestal and I'm a leg guy.my dealer took my 2300 in trade and dropped this off Wed. Couple hours and had it in.i burn 24/7 and it gets real cold here.i load ns all the time.osburn has awesome tech support .Was there any consideration for the 3500? From my understanding the 3300 is more geared towards NS loading and the 3500 EW loading. What is are the firebox dimensions of the 3300? Do you intend to burn NS? I am considering an Osburn, not sure which model just yet, trying to understand the comparison. Great looking setup you have
Go on the website .all the specs are there.So what is the major difference between them? Is there a difference in heat output? Is it the blower on the 3500?
You will likely find more reviews on the Drolet equivalents. Same firebox, but with upscale trim.Agreed. Wasnt sure how many people have actual experience with either model.
What kinda money are those 3300 in the US?I liked the blower on my 2300 when it was real cold out .not sure I'm going to buy one for my 3300I spoke to a dealer today and heavily leaning Obsurn 3300. Not sure I need a blower that the 3500 comes with could add it later. I like the leg look as well, though it will be in my basement. Basically the same firebox in both, not sure how the 3500 is rated for hight BTU than 3300, doesn't make much sense since your BTU's are in the wood, not the stove.
Which stove do you love Rob? What model Hearthstone do you currently have?
If it burns anywhere close to how my 2300 burned. It will be a beastThe 3300 is steel with a cast door. I also was looking at the bigger Green Mountain 80, but also wanted to go a non cat route. The large firebox on the 3300 seems ideal, and the height ro the burn tubes is right around 14". Seems like NS loading is the way to go, but the 3300 allows for both without drastically changing log length.
