Hi all, I've read enough to know that most folks here are not fans of Franklin stoves, and I appreciate all the good reasons not to install one.
But I hoping someone familiar with the beast could recommend a chimney set up that will allow me to enjoy burning one as a fire place.
I don't have a stove on hand but I believe that they are designed for a 7" flue.
My assumption is that I would have an uninsulated 90 degree bend to an insulated port through the back wall and another 90 degree turn and then approximately 20 feet up. Another assumption is that I could put an insulated "T" on the bottom to simplify cleaning the chimney.
What I'm not sure about is how the modern chimney will work with the hotter exhaust from a non air tight stove frequently burned as an open fire place.
I'd also like to make sure that I can install a more modern fire place on the same chimney when and if the Franklin looses its charm.
Thanks, Woody
Thanks, Woody
