brant2000
Mini's have two heads and one unit outside. At least that's what iv been told
I believe those are mitsubishi's "city multi" units. There may be others that use a similar arrangement, but these were the original.
Maybe it's just my unit, but I'm very skeptical about the HSPF vs. "real world" efficiencies.
Having grown-up in the "bogus" era of conventional ducted heat pumps, I was very skeptical of mini-split claims. To me, heat pumps were inefficient ways to blow ~75 degree heat around the house
Conventional ~12 SEER heat pumps are no comparison to a good mini-split.
BTW how much noise do mini splits make? Would I be annoyed having one right over my bed?
I also have heard great things about minisplits. My comment was in regard to large, ducted split systems like mine. Just like you mention in your post, mine blows slightly warmed air and runs constantly when it's cold out. Aside from the expensive electric bill, the constant noise of my blower running 24x7 drove me nuts.Yes, it is just your unit, and I was very skeptical as well before I read all of the glowing reviews about the mini-split performance in cold weather. But they deliver.
My Mitsu mini split has three speeds. It is quite quiet on low but is noticeable when on medium. On high its noisy. Mine is mounted very close to where I sit to watch TV so it location is also an issue but I needed to put it there to get the outside unit in the best spot (Out of the prevailing winds and on a sunny wall) In normal operation running it on low is fine. If the unit has been set back and I need to heat the area up, medium is needed for an hour or two. I heat the second floor of my house with the unit on the first floor when possible and in cold condition, I need to run the fan on high. One thing to be aware of is the amount of heat the unit puts out drops as its gets colder while the amount of heat you need goes up. The unit still puts out heat at subzero temps but the btu/hr and the temp also drops. I found this winter that in cold temps, the unit really doesn't deal well with setting back the temp, just set it at one setting and leave it.
In cold damp or snowy conditions, they are somewhat noticeable when going through a defrost cycle. Its not that it loud as much as it sounds like someone is messing with the controls as it cycled through the defrost cycle. If its clear out, it doesnt happen often but in cold snowy conditions it may cycle every hour.
