I just came up with the idea and was wondering if anyone may have done something similar or has thoughts they'd like to share. What I was thinking about would be to place a flat plate HX as the first user in a simple pressurized loop (near boiler outlet) and use a circulator on the storage side of the HX to control charging/discharging of storage. This would be using an open storage tank. Not sure if you could do it with a single pump or not, but was thinking the flow could be reversed to optimize this (draw off the bottom to store / draw off the top to charge).
The benefit I see to doing this is really that flat plate HX's are cheap and this could be done with one vs. two that are normally required. Also, may provide simpler control of charging/discharging.
